General Skidsteer & Technical Topics
Shop Talk
S150 engine
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 63951" data-attributes="member: 82"><p>I must have over looked this one.</p><p>Ebay, get another V2203 off there. There are quite a few that used to be on refrigerated trucks. You may need to swap the sump and manifolds, but they should work pretty much the same. They may be v2203-E not the V2203-DI you probably have. One is direct injection (DI) the other is not.</p><p>I think there is 2hp between the two.</p></blockquote><p></p>
[QUOTE="Tazza, post: 63951, member: 82"] I must have over looked this one. Ebay, get another V2203 off there. There are quite a few that used to be on refrigerated trucks. You may need to swap the sump and manifolds, but they should work pretty much the same. They may be v2203-E not the V2203-DI you probably have. One is direct injection (DI) the other is not. I think there is 2hp between the two. [/QUOTE]
Verification
Post reply
Shop Talk
S150 engine
