Bobcat Skidsteer Forums
S150 Charge Pressure Shutdown
Reply to thread
Message
<blockquote data-quote="7LBSSMALLIE" data-source="post: 54663" data-attributes="member: 6879"><p>idler tips. place in vice clamp with vice grips,spray withh pb turn handle on vice while tapping with hammer should collaspe to spring load, open and close it afew times than never seize, if u shape has divots need to replace it. as to why parts exceed replacemant i do not know and have issues with. another tip is to place the locking tab from a zip tie in it at1203 postition, foresaken that top spot it doesnt want to rotate out of, and personally bcd where you at im in the midwest</p></blockquote><p></p>
[QUOTE="7LBSSMALLIE, post: 54663, member: 6879"] idler tips. place in vice clamp with vice grips,spray withh pb turn handle on vice while tapping with hammer should collaspe to spring load, open and close it afew times than never seize, if u shape has divots need to replace it. as to why parts exceed replacemant i do not know and have issues with. another tip is to place the locking tab from a zip tie in it at1203 postition, foresaken that top spot it doesnt want to rotate out of, and personally bcd where you at im in the midwest [/QUOTE]
Verification
Post reply
