Bobcat Skidsteer Forums
S130 Charging
Reply to thread
Message
<blockquote data-quote="Wellsy" data-source="post: 72860" data-attributes="member: 10400"><p>There is no aux connector, and I had the alternator tested and gone through. It does however have the back up alarm so should I try disconnecting the two switches you mentioned? Is it the actual switches that could cause this problem or the wiring to the switches?</p></blockquote><p></p>
[QUOTE="Wellsy, post: 72860, member: 10400"] There is no aux connector, and I had the alternator tested and gone through. It does however have the back up alarm so should I try disconnecting the two switches you mentioned? Is it the actual switches that could cause this problem or the wiring to the switches? [/QUOTE]
Verification
Post reply
S130 Charging
