Bobcat Skidsteer Forums
S-175 belt
Reply to thread
Message
<blockquote data-quote="Bobcatdan" data-source="post: 82106" data-attributes="member: 7339"><p>The S175 has a pointer style tensioner. The pointer maybe gone, it happens. Remove the bolt holding the tensioner on completely and pull the tensioner out. Remove and replace belt. Install tensioner with the bolt snug, but not tight. A 3' bar works best. Pry down until you feel it bottom out, then release it back off slightly. Tighten bolt. The pointer should be at 3 o'clock, but if gone is really not needed. Recheck after several hours. Everything I have said should be clearly outlined on a decal on the inside of the back door.</p></blockquote><p></p>
[QUOTE="Bobcatdan, post: 82106, member: 7339"] The S175 has a pointer style tensioner. The pointer maybe gone, it happens. Remove the bolt holding the tensioner on completely and pull the tensioner out. Remove and replace belt. Install tensioner with the bolt snug, but not tight. A 3' bar works best. Pry down until you feel it bottom out, then release it back off slightly. Tighten bolt. The pointer should be at 3 o'clock, but if gone is really not needed. Recheck after several hours. Everything I have said should be clearly outlined on a decal on the inside of the back door. [/QUOTE]
Verification
Post reply
S-175 belt
