Bobcat Skidsteer Forums
Remote start switch
Reply to thread
Message
<blockquote data-quote="OldMachinist" data-source="post: 84574" data-attributes="member: 437"><p>The remote switch MEL1138A was just another ignition switch that plugged into the harness connector that you have to disconnect to raise the cab. You can do the same thing with a jumper wire to energize the ignition circuit and a automotive remote starter switch.</p><p>Run a jumper from 12+(red wire #1D) to the white/black wire #23F in the harness connector, this will be like turning the key to on. Connect the remote starter switch from the battery to the smaller terminal on the starter solenoid.</p><p><img src="http://i245.photobucket.com/albums/gg49/calfranch/Bobcat/642b/EngineWiring_zpszpgihsx4.jpg" alt=" photo EngineWiring_zpszpgihsx4.jpg" class="fr-fic fr-dii fr-draggable " style="width: 803px; height: 580px" /></p><p>Start the engine with the remote switch, do your adjustments and just remove the jumper wire to shut down.</p></blockquote><p></p>
[QUOTE="OldMachinist, post: 84574, member: 437"] The remote switch MEL1138A was just another ignition switch that plugged into the harness connector that you have to disconnect to raise the cab. You can do the same thing with a jumper wire to energize the ignition circuit and a automotive remote starter switch. Run a jumper from 12+(red wire #1D) to the white/black wire #23F in the harness connector, this will be like turning the key to on. Connect the remote starter switch from the battery to the smaller terminal on the starter solenoid. [IMG width="803px" height="580px" alt=" photo EngineWiring_zpszpgihsx4.jpg"]http://i245.photobucket.com/albums/gg49/calfranch/Bobcat/642b/EngineWiring_zpszpgihsx4.jpg[/IMG] Start the engine with the remote switch, do your adjustments and just remove the jumper wire to shut down. [/QUOTE]
Verification
Post reply
Remote start switch
