Other Brand Skidsteer Forums
New Holland Skidsteer Forum
Procedure after hydrostat rebuild
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 81384" data-attributes="member: 82"><p>I can't see why you can't do it with just the tilt ram. You just want something to draw oil through the pump. Ideally a vacuum pump on a hydraulic line would pull oil through, but not everyone has one to hook up. You don't want to use the household vacuum cleaner and then incur the wife's wraith when you fill it with oil.</p><p>I have never had issues with just using a cylinder to draw oil into the pumps though. Even if you disconnect the fuel shut off solenoid and crank the engine to get oil moving before it gets up to speed.</p></blockquote><p></p>
[QUOTE="Tazza, post: 81384, member: 82"] I can't see why you can't do it with just the tilt ram. You just want something to draw oil through the pump. Ideally a vacuum pump on a hydraulic line would pull oil through, but not everyone has one to hook up. You don't want to use the household vacuum cleaner and then incur the wife's wraith when you fill it with oil. I have never had issues with just using a cylinder to draw oil into the pumps though. Even if you disconnect the fuel shut off solenoid and crank the engine to get oil moving before it gets up to speed. [/QUOTE]
Verification
Post reply
