Other Brand Skidsteer Forums
Case Skidsteer Forum
new to me 1845 questions. (model, what engine, wiring)
Reply to thread
Message
<blockquote data-quote="Yoda" data-source="post: 54109" data-attributes="member: 6621"><p>I bought an 1845c about a year ago, I'm new to skid steers myself so by no means an expert but I thought the c stood for cummins. Pretty sure if you have a diesel engine your machine is a 1845c and it is a cummins. I think the ether cold start was an option, you probably do not need it hooked up, especially if you can plug in the block heater in cold weather. I think my charging system light does come on when you key on then goes out after it starts, you may just have a burnt out bulb, you could hook a voltmeter to the battery, start the machine and check what it reads, it should read between around 13.5 to 14.6 if your alternator is working. Can't help on the wiring diagram but here is a link to look up parts and part numbers http://www.colemanequip.com/Case_Parts.asp#Skid_Steer_Parts</p></blockquote><p></p>
[QUOTE="Yoda, post: 54109, member: 6621"] I bought an 1845c about a year ago, I'm new to skid steers myself so by no means an expert but I thought the c stood for cummins. Pretty sure if you have a diesel engine your machine is a 1845c and it is a cummins. I think the ether cold start was an option, you probably do not need it hooked up, especially if you can plug in the block heater in cold weather. I think my charging system light does come on when you key on then goes out after it starts, you may just have a burnt out bulb, you could hook a voltmeter to the battery, start the machine and check what it reads, it should read between around 13.5 to 14.6 if your alternator is working. Can't help on the wiring diagram but here is a link to look up parts and part numbers http://www.colemanequip.com/Case_Parts.asp#Skid_Steer_Parts [/QUOTE]
Verification
Post reply
