Other Brand Skidsteer Forums
New Holland Skidsteer Forum
New holland cab heater.
Reply to thread
Message
<blockquote data-quote="mfyock" data-source="post: 84767" data-attributes="member: 2150"><p>I have installed the maradyne heater that is real thin and fits behind the seat. I think its the same setup SIMS offers for the NH machines. Its ok, only issue is everytime you tilt the seat up the hoses to the heater core flex. I had one machine that this flexing cracked the solder joint on the heater core, then antifreeze started leaking out... I have also seen a small heater mounted on the control valve cover between your feet. This worked well but was a real pain climbing in and out of the skidsteer...</p></blockquote><p></p>
[QUOTE="mfyock, post: 84767, member: 2150"] I have installed the maradyne heater that is real thin and fits behind the seat. I think its the same setup SIMS offers for the NH machines. Its ok, only issue is everytime you tilt the seat up the hoses to the heater core flex. I had one machine that this flexing cracked the solder joint on the heater core, then antifreeze started leaking out... I have also seen a small heater mounted on the control valve cover between your feet. This worked well but was a real pain climbing in and out of the skidsteer... [/QUOTE]
Verification
Post reply
