Other Brand Skidsteer Forums
Case Skidsteer Forum
Looking at a 40XT
Reply to thread
Message
<blockquote data-quote="CNeubauer" data-source="post: 71925" data-attributes="member: 8400"><p>Might be too late to help you but during the XT production they came out with a new wheel motor that was supposed to fix the problem. I forget the details but on the early ones the motor would loose the bearing preload and take out the seals. From what I could find out the early models with the serial number starting with JAF had the problem motors and when the solved that they went to serial numbers starting with JAF0. We bought a late 70XT 14 months ago that had 4,000 hours and we've put 350 hours on it with zero problems. The 40,60 and 70XT all use the same chassis.</p></blockquote><p></p>
[QUOTE="CNeubauer, post: 71925, member: 8400"] Might be too late to help you but during the XT production they came out with a new wheel motor that was supposed to fix the problem. I forget the details but on the early ones the motor would loose the bearing preload and take out the seals. From what I could find out the early models with the serial number starting with JAF had the problem motors and when the solved that they went to serial numbers starting with JAF0. We bought a late 70XT 14 months ago that had 4,000 hours and we've put 350 hours on it with zero problems. The 40,60 and 70XT all use the same chassis. [/QUOTE]
Verification
Post reply
Looking at a 40XT
