Bobcat Skidsteer Forums
Is there a trick?
Reply to thread
Message
<blockquote data-quote="ancomcabs" data-source="post: 48763" data-attributes="member: 6435"><p>Thanks, does that screw come off first? I've had mine a couple weeks now and for the most part she runs well considering the age. Hour meter was broken and stopped at a little over 1500 so I'm not sure how many actual but to be honest it looks like it could be pretty close. Biggest thing with mine is it looks like it sat under a tree or something for years, still pulling old leaves and debris off it, finding bee's nests etc. Has a lot of rust but I'm just wanting to get it ready for winter, if it runs well and reliable them I'll probably sink some time into it next spring/summer to take things apart and repaint. Have you replaced any pins yet, mine seem pretty tight with the exception of the tilt one that attaches by the bucket, wondering how much trouble it is to change it out? Any idea what the best way to drain the hydraulic fluid is? manual says remove on of the hoses up by the filter? Also seems like the only way to remove the chain case fluid is with a pump, Mines full but looks like it has been contaminated with water</p></blockquote><p></p>
[QUOTE="ancomcabs, post: 48763, member: 6435"] Thanks, does that screw come off first? I've had mine a couple weeks now and for the most part she runs well considering the age. Hour meter was broken and stopped at a little over 1500 so I'm not sure how many actual but to be honest it looks like it could be pretty close. Biggest thing with mine is it looks like it sat under a tree or something for years, still pulling old leaves and debris off it, finding bee's nests etc. Has a lot of rust but I'm just wanting to get it ready for winter, if it runs well and reliable them I'll probably sink some time into it next spring/summer to take things apart and repaint. Have you replaced any pins yet, mine seem pretty tight with the exception of the tilt one that attaches by the bucket, wondering how much trouble it is to change it out? Any idea what the best way to drain the hydraulic fluid is? manual says remove on of the hoses up by the filter? Also seems like the only way to remove the chain case fluid is with a pump, Mines full but looks like it has been contaminated with water [/QUOTE]
Verification
Post reply
Is there a trick?
