Other Brand Skidsteer Forums
Kubota/Wacker Neuson/Hesston/IH/Ford/Other
CTL/skid steer for logging/plowing?
Reply to thread
Message
<blockquote data-quote="xcmark" data-source="post: 31317" data-attributes="member: 3346"><p>track loader will be better in soft ground. Plowing the driveway if its got any grade to it your going to need chains or studs in the tires or tracks for sure. Maxgrip is screw in stud for tires/tracks I think it should solve that problem. Keep in mind a set of new tires and a set of steel tracks is about the same price as a short set of rubber tracks. The tracks on my JCB 1110t are over $4000 and tracks for the larger cat /asv loader are about the same. thats just tracks , no idlers,no bogies..... you get anywhere from 400~1500 hours out of a rubber track and tires figure 400~600 hours depends on what its running on and who is running it.</p></blockquote><p></p>
[QUOTE="xcmark, post: 31317, member: 3346"] track loader will be better in soft ground. Plowing the driveway if its got any grade to it your going to need chains or studs in the tires or tracks for sure. Maxgrip is screw in stud for tires/tracks I think it should solve that problem. Keep in mind a set of new tires and a set of steel tracks is about the same price as a short set of rubber tracks. The tracks on my JCB 1110t are over $4000 and tracks for the larger cat /asv loader are about the same. thats just tracks , no idlers,no bogies..... you get anywhere from 400~1500 hours out of a rubber track and tires figure 400~600 hours depends on what its running on and who is running it. [/QUOTE]
Verification
Post reply
