Bobcat Skidsteer Forums
controller for 753G
Reply to thread
Message
<blockquote data-quote="fiddlearound" data-source="post: 34737" data-attributes="member: 3385"><p>Just an update that should be helpful. Mechanic decided to start over with basics. Load tested the battery and found a bad ground. I had checked for continuity and that was okay, but still not a good enough ground. He cleaned and replaced until the ground was good and old faithful fired right up. So lesson learned--start with a good battery and a good ground!! Thanks for the suggestions from the board.</p></blockquote><p></p>
[QUOTE="fiddlearound, post: 34737, member: 3385"] Just an update that should be helpful. Mechanic decided to start over with basics. Load tested the battery and found a bad ground. I had checked for continuity and that was okay, but still not a good enough ground. He cleaned and replaced until the ground was good and old faithful fired right up. So lesson learned--start with a good battery and a good ground!! Thanks for the suggestions from the board. [/QUOTE]
Verification
Post reply
controller for 753G
