Other Brand Skidsteer Forums
Case Skidsteer Forum
Case 1840 died while operating
Reply to thread
Message
<blockquote data-quote="SethA" data-source="post: 74453" data-attributes="member: 10485"><p>On the right hand side of the machine just behind the rops there are three main harness connections, I have seen the pins corrode inside of the plugs, there is also a main fuse there I would check there first, also the harness just above the bell housing is susceptible to wear due to vibration</p></blockquote><p></p>
[QUOTE="SethA, post: 74453, member: 10485"] On the right hand side of the machine just behind the rops there are three main harness connections, I have seen the pins corrode inside of the plugs, there is also a main fuse there I would check there first, also the harness just above the bell housing is susceptible to wear due to vibration [/QUOTE]
Verification
Post reply
