Other Brand Skidsteer Forums
Case Skidsteer Forum
Case 1816C How to adjust Creep?
Reply to thread
Message
<blockquote data-quote="Honky Lips" data-source="post: 81398" data-attributes="member: 11629"><p>there is a threaded adjustment in between the bolt that attaches to the pump rod and the linkage to the control arm. you need to loosen both jam nuts and i believe make the rod longer. do a small ajustment one way, and then go from there. hopefully my sad description helps.</p></blockquote><p></p>
[QUOTE="Honky Lips, post: 81398, member: 11629"] there is a threaded adjustment in between the bolt that attaches to the pump rod and the linkage to the control arm. you need to loosen both jam nuts and i believe make the rod longer. do a small ajustment one way, and then go from there. hopefully my sad description helps. [/QUOTE]
Verification
Post reply
