Other Brand Skidsteer Forums
Case Skidsteer Forum
Case 1816 Drive Belt replacement
Reply to thread
Message
<blockquote data-quote="lesgawlik" data-source="post: 52836" data-attributes="member: 4115"><p>Since I first posted this, I've learned a little more. It may be possible to loosen the clutch set screw and move the clutch aft on the shaft. That may give enough play to slip the belt over. I have a very hard time starting those engine bolts. There is just not enough room to get my fingers under the angle iron and start the bolt. The next time the engine comes out, I'm going to cut a large hole in the plate between the seat and motor, and then I'd be able to just slip the belts on and off without having to loosen anything.</p></blockquote><p></p>
[QUOTE="lesgawlik, post: 52836, member: 4115"] Since I first posted this, I've learned a little more. It may be possible to loosen the clutch set screw and move the clutch aft on the shaft. That may give enough play to slip the belt over. I have a very hard time starting those engine bolts. There is just not enough room to get my fingers under the angle iron and start the bolt. The next time the engine comes out, I'm going to cut a large hole in the plate between the seat and motor, and then I'd be able to just slip the belts on and off without having to loosen anything. [/QUOTE]
Verification
Post reply
