Bobcat Skidsteer Forums
Bucket won't Curl and Tilt
Reply to thread
Message
<blockquote data-quote="mickeyhedges" data-source="post: 76921" data-attributes="member: 11052"><p>Thankyou for that I have a manual on pdf but much harder to follow than the above, I noticed the aux coils had a tag about voltage not the BICS coil so I didn't know, I am not sure why the rear Aux Coil is powering and not the front should It even be powered without the aux on, that's y I was questioning the Aux being stuck on or something,maybe I can find something with this I had to print off stuff and label colors corresponding to #s on the key so was sorta confusing hopefully this will lead me, thanks for your time, much appreciated.</p></blockquote><p></p>
[QUOTE="mickeyhedges, post: 76921, member: 11052"] Thankyou for that I have a manual on pdf but much harder to follow than the above, I noticed the aux coils had a tag about voltage not the BICS coil so I didn't know, I am not sure why the rear Aux Coil is powering and not the front should It even be powered without the aux on, that's y I was questioning the Aux being stuck on or something,maybe I can find something with this I had to print off stuff and label colors corresponding to #s on the key so was sorta confusing hopefully this will lead me, thanks for your time, much appreciated. [/QUOTE]
Verification
Post reply
