Bobcat Skidsteer Forums
Bobcat 763 BICS module NO power ?
Reply to thread
Message
<blockquote data-quote="7LBSSMALLIE" data-source="post: 53707" data-attributes="member: 6879"><p>DIELECTRIC GREASE BOYS,if you unplug one put it on not just the pins but the coonector itself. easy stuff headaches down the road gone, once harness poked and prodded, intergrity in question. go from pin to pin if if poked and prodded, for instance a 5 strAnd coumaction wire. test light broke three ohm check ok but wont carrya load. is alomost impossible to find. pin to pin not poke. once hacked only viable t/s i is replacement and start from scratch,763 bics easy stuff. push to operate kit, boss gets diffuclt. only option is to bring back to factory spec.(at times all the saftey features seem stupid, that is untill you have to help fire dept extract 18 yr old from unit, keep it safe,(to reiterate. make no mistake these will hurt you in a ny second).</p></blockquote><p></p>
[QUOTE="7LBSSMALLIE, post: 53707, member: 6879"] DIELECTRIC GREASE BOYS,if you unplug one put it on not just the pins but the coonector itself. easy stuff headaches down the road gone, once harness poked and prodded, intergrity in question. go from pin to pin if if poked and prodded, for instance a 5 strAnd coumaction wire. test light broke three ohm check ok but wont carrya load. is alomost impossible to find. pin to pin not poke. once hacked only viable t/s i is replacement and start from scratch,763 bics easy stuff. push to operate kit, boss gets diffuclt. only option is to bring back to factory spec.(at times all the saftey features seem stupid, that is untill you have to help fire dept extract 18 yr old from unit, keep it safe,(to reiterate. make no mistake these will hurt you in a ny second). [/QUOTE]
Verification
Post reply
