Bobcat Skidsteer Forums
Bobcat 610 Drive belts
Reply to thread
Message
<blockquote data-quote="KSC-Direct" data-source="post: 85165" data-attributes="member: 11141"><p>I have received a few calls based on this thread now, the first guy bought a PIX 2926V616 belt that we have crossreferenced on our site-see link below. He never called back, so I assume it worked out for him. http://kscdirect.com/item/PIX%2B2926V616/A%2B%2526%2BI%2BPRODUCTS_VARIABLE%2BSPEED%2BBELT When the 2nd customer called, PIX was on backorder, so I substituted a Bando 2926V616--should be indenticle to industry standard for a 2926V616 belt. However, he said the belt was too thing, measuring 1/2" thick, and snt it back without trying it. I do not know if it would have worked. I did some research and the Gates belt is also 1/2" thick, I was not able to get a thickness spec from PIX. If anyone can provide some information about how thick the belt they are using is, that may be a key to which of these works well or doesn't? I also called Bobcat of the Rockies, a dealer here in Denver, Colorado. He said that part# 6515271 is a current Bobcat part# for the main drive belt on a Bobcat 610. He also said that part# 6515371 is the alternator belt for that model. He advised that they currently had one in stock in their store in Windsor, CO at a price of $112.38 (obviously subject to change and availability may vary). If you want to try an aftermarket belt, my best advice is it should work and I can sell it to you, but I can't guarantee an exact factory fit and performance. If you want that, I would recommend calling an authorized Bobcat dealer. http://bobcat.know-where.com/bobcat/ Best regards, Gavin Johnson Kelly Supply Company www.kscdirect.com</p></blockquote><p></p>
[QUOTE="KSC-Direct, post: 85165, member: 11141"] I have received a few calls based on this thread now, the first guy bought a PIX 2926V616 belt that we have crossreferenced on our site-see link below. He never called back, so I assume it worked out for him. http://kscdirect.com/item/PIX%2B2926V616/A%2B%2526%2BI%2BPRODUCTS_VARIABLE%2BSPEED%2BBELT When the 2nd customer called, PIX was on backorder, so I substituted a Bando 2926V616--should be indenticle to industry standard for a 2926V616 belt. However, he said the belt was too thing, measuring 1/2" thick, and snt it back without trying it. I do not know if it would have worked. I did some research and the Gates belt is also 1/2" thick, I was not able to get a thickness spec from PIX. If anyone can provide some information about how thick the belt they are using is, that may be a key to which of these works well or doesn't? I also called Bobcat of the Rockies, a dealer here in Denver, Colorado. He said that part# 6515271 is a current Bobcat part# for the main drive belt on a Bobcat 610. He also said that part# 6515371 is the alternator belt for that model. He advised that they currently had one in stock in their store in Windsor, CO at a price of $112.38 (obviously subject to change and availability may vary). If you want to try an aftermarket belt, my best advice is it should work and I can sell it to you, but I can't guarantee an exact factory fit and performance. If you want that, I would recommend calling an authorized Bobcat dealer. http://bobcat.know-where.com/bobcat/ Best regards, Gavin Johnson Kelly Supply Company www.kscdirect.com [/QUOTE]
Verification
Post reply
