Bobcat Skidsteer Forums
bobcat 440b control valve leak
Reply to thread
Message
<blockquote data-quote="SkidRoe" data-source="post: 66214" data-attributes="member: 3290"><p>I am assuming that you are also working on a 440b. If so, that would be the control section for the boom lift. </p><p>And you will need to pull the control block out. There is just not enough room to do this job properly when it is in the machine. </p><p>Once you have it on the bench and start tearing into it, ou will be glad you pulled it out. Best of luck!!</p></blockquote><p></p>
[QUOTE="SkidRoe, post: 66214, member: 3290"] I am assuming that you are also working on a 440b. If so, that would be the control section for the boom lift. And you will need to pull the control block out. There is just not enough room to do this job properly when it is in the machine. Once you have it on the bench and start tearing into it, ou will be glad you pulled it out. Best of luck!! [/QUOTE]
Verification
Post reply
