Bobcat Skidsteer Forums
Actuator Failures and Replacement, Computers and Software
Reply to thread
Message
<blockquote data-quote="Axel" data-source="post: 95910" data-attributes="member: 11648"><p>Just DISCONNECTED almost EVERYTHING from the BICS valve EXCEPT for the BICS VALVE SOLENOID , Ran the machine grading a driveway for 20 minutes without any lockout or lights flashing. However now that I've become very sensitized to noticing "HICCUPS/Lockout" , I did notice that the lift movement is not very smooth, mostly on the down motion when feathering the left(lift) handle. I'm guessing this is a hydraulic symptom? Btw, the machine is an 863F with the aluminum controller and Green printed text BICS module behind right elbow. I've been informed that the one with black text is more common...</p></blockquote><p></p>
[QUOTE="Axel, post: 95910, member: 11648"] Just DISCONNECTED almost EVERYTHING from the BICS valve EXCEPT for the BICS VALVE SOLENOID , Ran the machine grading a driveway for 20 minutes without any lockout or lights flashing. However now that I've become very sensitized to noticing "HICCUPS/Lockout" , I did notice that the lift movement is not very smooth, mostly on the down motion when feathering the left(lift) handle. I'm guessing this is a hydraulic symptom? Btw, the machine is an 863F with the aluminum controller and Green printed text BICS module behind right elbow. I've been informed that the one with black text is more common... [/QUOTE]
Verification
Post reply
