Bobcat Skidsteer Forums
98 863 main control valve removal HELP
Reply to thread
Message
<blockquote data-quote="skidsteer.ca" data-source="post: 23768" data-attributes="member: 307"><p>You already did the hard part, you might as well change the seals, the detent balls are a bear, but should be replaced when the valve is out as they tend to rust and the float function no longer locks on. Sometimes you need to butcher up a wrench or to to get all the fitting good and tight in the minimal space provided.</p><p>Ken</p></blockquote><p></p>
[QUOTE="skidsteer.ca, post: 23768, member: 307"] You already did the hard part, you might as well change the seals, the detent balls are a bear, but should be replaced when the valve is out as they tend to rust and the float function no longer locks on. Sometimes you need to butcher up a wrench or to to get all the fitting good and tight in the minimal space provided. Ken [/QUOTE]
Verification
Post reply
