Bobcat Skidsteer Forums
98 753 Fan Belt Tensioner/Belt issue causing overheating
Reply to thread
Message
<blockquote data-quote="Bobcatdan" data-source="post: 78658" data-attributes="member: 7339"><p>The tensioner being tight was your problem. The fan gear box is just a right angle drive, if it locked up, it would be done for. Flip the cab, pull the pipe plug out of the fan drive. Make sure the drive is full of 80w90 to the bottom of the fill hole.</p></blockquote><p></p>
[QUOTE="Bobcatdan, post: 78658, member: 7339"] The tensioner being tight was your problem. The fan gear box is just a right angle drive, if it locked up, it would be done for. Flip the cab, pull the pipe plug out of the fan drive. Make sure the drive is full of 80w90 to the bottom of the fill hole. [/QUOTE]
Verification
Post reply
