Bobcat Skidsteer Forums
853, blowing eng fuses hot wired now aux hyd no worky
Reply to thread
Message
<blockquote data-quote="kilohertz" data-source="post: 95144" data-attributes="member: 6974"><p>Can't be 100% sure, but I think those two plugs you refer to in the last pic, 1 and 3, go to some little micro switches on the forward/reverse sticks, under the cab. The switches are mounted right on a bracket centered between the control cables going to the hydro-stats. They turn on/off as soon as the sticks come off neutral. I have no idea why they are there, or what they do, as they are disconnected on my machine, and my machine works fine, and probably why I wasn't too concerned when I saw where they went on my buddies machine. You can confirm with an ohm meter...but I think that's where they go. If something else comes to me, I'll let you know.</p><p>Let us know what you find.</p><p>Cheers</p></blockquote><p></p>
[QUOTE="kilohertz, post: 95144, member: 6974"] Can't be 100% sure, but I think those two plugs you refer to in the last pic, 1 and 3, go to some little micro switches on the forward/reverse sticks, under the cab. The switches are mounted right on a bracket centered between the control cables going to the hydro-stats. They turn on/off as soon as the sticks come off neutral. I have no idea why they are there, or what they do, as they are disconnected on my machine, and my machine works fine, and probably why I wasn't too concerned when I saw where they went on my buddies machine. You can confirm with an ohm meter...but I think that's where they go. If something else comes to me, I'll let you know. Let us know what you find. Cheers [/QUOTE]
Verification
Post reply
