Bobcat Skidsteer Forums
773 G Axle issue
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 83518" data-attributes="member: 82"><p>You can try talking to the dealer, i don't have high hopes but you can try.</p><p>It's possible that a machine shop can machine a new keyway on the opposite side. This will only work of the taper is still good, if it's damaged, you will need a new hub and shaft</p></blockquote><p></p>
[QUOTE="Tazza, post: 83518, member: 82"] You can try talking to the dealer, i don't have high hopes but you can try. It's possible that a machine shop can machine a new keyway on the opposite side. This will only work of the taper is still good, if it's damaged, you will need a new hub and shaft [/QUOTE]
Verification
Post reply
773 G Axle issue
