Bobcat Skidsteer Forums
763 Shooting hydraulic oil out the control valve?
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 65314" data-attributes="member: 82"><p>Are you talking about the spool or the cap on the back?</p><p>The spool can go in whatever way, it should be dead straight, if it binds, rotate it 180 degrees.</p><p>If you are talking about the cap, there should be a small spot on the face that bolts to the control block with a small groove cut in it, this should face down to let any water/oil out the bottom.</p></blockquote><p></p>
[QUOTE="Tazza, post: 65314, member: 82"] Are you talking about the spool or the cap on the back? The spool can go in whatever way, it should be dead straight, if it binds, rotate it 180 degrees. If you are talking about the cap, there should be a small spot on the face that bolts to the control block with a small groove cut in it, this should face down to let any water/oil out the bottom. [/QUOTE]
Verification
Post reply
