Bobcat Skidsteer Forums
753 bobcat no reverse left side
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 79476" data-attributes="member: 82"><p>Before you order a motor, check the shuttle valve on the motor. Look for an allen headed cap. Remove it and pull out the shuttle valve pieces, ensure they move freely when putting them back together. Hopefully it will fix the issue.</p><p>A seal kit will still be available for this motor, i don't believe you need a new one, just seals or a stuck shuttle valve.</p><p>They can be rebuilt, loader parts source will be able to get the parts for that.</p></blockquote><p></p>
[QUOTE="Tazza, post: 79476, member: 82"] Before you order a motor, check the shuttle valve on the motor. Look for an allen headed cap. Remove it and pull out the shuttle valve pieces, ensure they move freely when putting them back together. Hopefully it will fix the issue. A seal kit will still be available for this motor, i don't believe you need a new one, just seals or a stuck shuttle valve. They can be rebuilt, loader parts source will be able to get the parts for that. [/QUOTE]
Verification
Post reply
