Bobcat Skidsteer Forums
743 Cylinder Stop Mount
Reply to thread
Message
<blockquote data-quote="kyosho" data-source="post: 74392" data-attributes="member: 3504"><p>Thanks Machinist. I clearly have an older model that should have had the support located in the door. The door has holes in it - but no brackets and no support. The newer style support I have that I got used is like the one in the picture above. My lift arm does not have the rod at the front nor the bracket at the back. So, I have an older style lift arm with a newer style lift arm support. I guess I'll be storing it in the barn. Thank you for the photos - it cleared up all my questions related to this! And thank you for the clarification on the other points. God bless!</p></blockquote><p></p>
[QUOTE="kyosho, post: 74392, member: 3504"] Thanks Machinist. I clearly have an older model that should have had the support located in the door. The door has holes in it - but no brackets and no support. The newer style support I have that I got used is like the one in the picture above. My lift arm does not have the rod at the front nor the bracket at the back. So, I have an older style lift arm with a newer style lift arm support. I guess I'll be storing it in the barn. Thank you for the photos - it cleared up all my questions related to this! And thank you for the clarification on the other points. God bless! [/QUOTE]
Verification
Post reply
