General Skidsteer & Technical Topics
Shop Talk
741 w/ no motor
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 34658" data-attributes="member: 82"><p>Whatever engine you use needs to be short enough to fit in the engine bay. It also needs a govenor, a stardard car engine will not work properly, it need s a govenor to maintain speed under vairous loads. The splined shaft on the pump has a mating coupler that slides over it connected to the fly wheel with two universal joints. Thats how they connected the pump to the engine. It allows for slight mis-alignment.</p></blockquote><p></p>
[QUOTE="Tazza, post: 34658, member: 82"] Whatever engine you use needs to be short enough to fit in the engine bay. It also needs a govenor, a stardard car engine will not work properly, it need s a govenor to maintain speed under vairous loads. The splined shaft on the pump has a mating coupler that slides over it connected to the fly wheel with two universal joints. Thats how they connected the pump to the engine. It allows for slight mis-alignment. [/QUOTE]
Verification
Post reply
Shop Talk
741 w/ no motor
