Bobcat Skidsteer Forums
722 Back with a new problem.
Reply to thread
Message
<blockquote data-quote="ChandlerW" data-source="post: 83455" data-attributes="member: 9823"><p>Is it possible that too small of an o-ring (number 12 in the image) would cause leakage past the spool valve? The original o-ring was split so I put a new one in. I didn't buy an OEM o-ring, just got one from my collection. Im thinking the o-ring may be too small, fluid gets past it and the pressure pushes the spool valve forward. After a period of time the pressure will bleed off and the pedal will function as normal. That's my theory</p></blockquote><p></p>
[QUOTE="ChandlerW, post: 83455, member: 9823"] Is it possible that too small of an o-ring (number 12 in the image) would cause leakage past the spool valve? The original o-ring was split so I put a new one in. I didn't buy an OEM o-ring, just got one from my collection. Im thinking the o-ring may be too small, fluid gets past it and the pressure pushes the spool valve forward. After a period of time the pressure will bleed off and the pedal will function as normal. That's my theory [/QUOTE]
Verification
Post reply
