Bobcat Skidsteer Forums
610 driven shaft key way
Reply to thread
Message
<blockquote data-quote="mark18mwm" data-source="post: 98770" data-attributes="member: 9306"><p>Well, I think I came up with a plan. I'm going to get a new shaft and nut and try to "clean up" the sheave. The shaft is $180 and the nut $8 at bobcat. The new sheave is $550 for the entire assembly, I only need the tapered half so I'll see if I can come up with a used half or assembly. I'll look around the next couple days and if I can't find a good used one I'll go with trying to clean mine up to use again. I have a lathe, but I'm not to good on it and with it being a taper I'll see if I can find someone to cut it.</p></blockquote><p></p>
[QUOTE="mark18mwm, post: 98770, member: 9306"] Well, I think I came up with a plan. I'm going to get a new shaft and nut and try to "clean up" the sheave. The shaft is $180 and the nut $8 at bobcat. The new sheave is $550 for the entire assembly, I only need the tapered half so I'll see if I can come up with a used half or assembly. I'll look around the next couple days and if I can't find a good used one I'll go with trying to clean mine up to use again. I have a lathe, but I'm not to good on it and with it being a taper I'll see if I can find someone to cut it. [/QUOTE]
Verification
Post reply
