Bobcat Skidsteer Forums
543b wiring
Reply to thread
Message
<blockquote data-quote="chester" data-source="post: 80690" data-attributes="member: 11405"><p>After trying to buy the heater block for the entry point I thought was proper. I ultimately realized I must have been trying to use a drain hole for the coolant. No block heater I purchased would fit. I will try to look at things again tonight. I just would rather find the right spot to insert the heater, want to be as less as invasive as possible, rather than popping a hole into the block I am chalking this all upto a learning curve. But still frustrating</p></blockquote><p></p>
[QUOTE="chester, post: 80690, member: 11405"] After trying to buy the heater block for the entry point I thought was proper. I ultimately realized I must have been trying to use a drain hole for the coolant. No block heater I purchased would fit. I will try to look at things again tonight. I just would rather find the right spot to insert the heater, want to be as less as invasive as possible, rather than popping a hole into the block I am chalking this all upto a learning curve. But still frustrating [/QUOTE]
Verification
Post reply
543b wiring
