Bobcat Skidsteer Forums
463/S70 tensioner spring?
Reply to thread
Message
<blockquote data-quote="Dave463" data-source="post: 74227" data-attributes="member: 10626"><p>All 4 bolts removed and I can't move the engine enough to get the new pulley on. The oil fill line prevents me from moving it enough to the left. So I need to pull it straight back enough to get the pulley back on. I thought I had all the lines removed from the hydraulic pumps, but I must not. The engine moves back a little, but not enough. Any thoughts on what I missed? Are there some underneath the hydraulic pumps? BTW, I took your advice and I wired the tension rod to the engine so it won't spring back. Seems to be working fine so far. Thanks</p></blockquote><p></p>
[QUOTE="Dave463, post: 74227, member: 10626"] All 4 bolts removed and I can't move the engine enough to get the new pulley on. The oil fill line prevents me from moving it enough to the left. So I need to pull it straight back enough to get the pulley back on. I thought I had all the lines removed from the hydraulic pumps, but I must not. The engine moves back a little, but not enough. Any thoughts on what I missed? Are there some underneath the hydraulic pumps? BTW, I took your advice and I wired the tension rod to the engine so it won't spring back. Seems to be working fine so far. Thanks [/QUOTE]
Verification
Post reply
