Bobcat Skidsteer Forums
440B Bobcat bucket removal.
Reply to thread
Message
<blockquote data-quote="SkidRoe" data-source="post: 74497" data-attributes="member: 3290"><p>My 440b does have the old, small version bobtach that was used from the M371 up to the 453. The 463 and S70, as well as the MT5X machines, use a cut down version of the standard bobtach. The profile is the same, the locking pins are on the same centres, but it is 35" wide instead of 44".</p><p>The 463/S70 bobtach will not directly fit on a pre-463 machine, as the boom design has also changed.</p><p>No company I can find sells attachments with the pre-463 bobtach, I have had to fabicate all of my mounts for my 440b. I also built an adapter plate to fit standard bobtach attachments to my 440b. I use it with my auger:</p><p><a href="https://www.skidsteerforum.com/DesktopDefault.aspx?tabid=54&frmView=ShowPost&PostID=46095" target="_blank">http://www.skidsteerforum.com/DesktopDefault.aspx?tabid=54&frmView=ShowPost&PostID=46095</a></p><p>If you were to add a bobtach to your machine, I would buy a mount as shown in the link, cut the pin-on mount off of your bucket and weld them together.</p><p><a href="http://www.skidsteersolutions.com/mini-skid-steer-attachments/adaptors/bobcat-mt-adaptors/eterra-ua-52-to-bobcat-mt50-52-55-463-quick-attach/" target="_blank">http://www.skidsteersolutions.com/mini-skid-steer-attachments/adaptors/bobcat-mt-adaptors/eterra-ua-52-to-bobcat-mt50-52-55-463-quick-attach/</a></p><p>HTH</p></blockquote><p></p>
[QUOTE="SkidRoe, post: 74497, member: 3290"] My 440b does have the old, small version bobtach that was used from the M371 up to the 453. The 463 and S70, as well as the MT5X machines, use a cut down version of the standard bobtach. The profile is the same, the locking pins are on the same centres, but it is 35“ wide instead of 44“. The 463/S70 bobtach will not directly fit on a pre-463 machine, as the boom design has also changed. No company I can find sells attachments with the pre-463 bobtach, I have had to fabicate all of my mounts for my 440b. I also built an adapter plate to fit standard bobtach attachments to my 440b. I use it with my auger: [URL='https://www.skidsteerforum.com/DesktopDefault.aspx?tabid=54&frmView=ShowPost&PostID=46095']http://www.skidsteerforum.com/DesktopDefault.aspx?tabid=54&frmView=ShowPost&PostID=46095[/URL] If you were to add a bobtach to your machine, I would buy a mount as shown in the link, cut the pin-on mount off of your bucket and weld them together. [URL]http://www.skidsteersolutions.com/mini-skid-steer-attachments/adaptors/bobcat-mt-adaptors/eterra-ua-52-to-bobcat-mt50-52-55-463-quick-attach/[/URL] HTH [/QUOTE]
Verification
Post reply
