Bobcat Skidsteer Forums
2012 s630 no forward right motion...
Reply to thread
Message
<blockquote data-quote="Bobcatdan" data-source="post: 78765" data-attributes="member: 7339"><p>Check the wiring harness on the pumps. I had a S530 do the same thing. I shotgun a coil on it and problem reoccurred. On closer look I found a nastey rub where the harness was against the the chaincase. The unit will go to 50% speed management when it sees a fault with the drive.</p></blockquote><p></p>
[QUOTE="Bobcatdan, post: 78765, member: 7339"] Check the wiring harness on the pumps. I had a S530 do the same thing. I shotgun a coil on it and problem reoccurred. On closer look I found a nastey rub where the harness was against the the chaincase. The unit will go to 50% speed management when it sees a fault with the drive. [/QUOTE]
Verification
Post reply
