Other Brand Skidsteer Forums
Case Skidsteer Forum
2005 Case 410 engine knocking
Reply to thread
Message
<blockquote data-quote="frogfarmer" data-source="post: 72022" data-attributes="member: 4075"><p>No liners so no not removable. You can install a repair liner they run a hundred bucks plus labor per hole. The block may very well be good. Parts are very expensive and best sourced from the OEM. Some aftermarket stuff is out there but quality is so so. Did I mention expensive? Complete reman engines can be had for $4500 plus tax and shipping from legit rebuilders. In most cases for a production machine a complete engine is the way to go. If you can afford the down time and have the ability to fix it yourself the cost will be in the $3-4000 range.</p></blockquote><p></p>
[QUOTE="frogfarmer, post: 72022, member: 4075"] No liners so no not removable. You can install a repair liner they run a hundred bucks plus labor per hole. The block may very well be good. Parts are very expensive and best sourced from the OEM. Some aftermarket stuff is out there but quality is so so. Did I mention expensive? Complete reman engines can be had for $4500 plus tax and shipping from legit rebuilders. In most cases for a production machine a complete engine is the way to go. If you can afford the down time and have the ability to fix it yourself the cost will be in the $3-4000 range. [/QUOTE]
Verification
Post reply
