Bobcat Skidsteer Forums
1994? I Think 743 DS weak drive very noisy
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 73924" data-attributes="member: 82"><p>Let me try and think, the shittle valve in the motor should have a pin, two end caps that the two spring rests on, then two tapered bits that slide on the pin that the springs push into place.</p><p>The only other way to be sure is to crack open the other one and check it's parts too.</p></blockquote><p></p>
[QUOTE="Tazza, post: 73924, member: 82"] Let me try and think, the shittle valve in the motor should have a pin, two end caps that the two spring rests on, then two tapered bits that slide on the pin that the springs push into place. The only other way to be sure is to crack open the other one and check it's parts too. [/QUOTE]
Verification
Post reply
