Bobcat Skidsteer Forums
1992 743 bobcat starter removal issues
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 78864" data-attributes="member: 82"><p>It must have rusted on a little, give it a bit more attention to try and knock it free. There should only be 3 bolts holding it in place.</p><p>As a solenoid test, run a wire from the +ve terminal to the small wire on the back of the starter. If it fires right up every time, the issue is the relay under the air cleaner, not the solenoid on the starter its self</p></blockquote><p></p>
[QUOTE="Tazza, post: 78864, member: 82"] It must have rusted on a little, give it a bit more attention to try and knock it free. There should only be 3 bolts holding it in place. As a solenoid test, run a wire from the +ve terminal to the small wire on the back of the starter. If it fires right up every time, the issue is the relay under the air cleaner, not the solenoid on the starter its self [/QUOTE]
Verification
Post reply
