Other Brand Skidsteer Forums
Case Skidsteer Forum
1990 Case 1840 Hydraulic Drive Project
Reply to thread
Message
<blockquote data-quote="bobtaildog" data-source="post: 77590" data-attributes="member: 11066"><p>So an update on this project, I did remove the hoses from the right side drive motor and capped it at the tandem pump......i can kill the motor with forward and reverse movement of the swash plate. So in the process of all this, I decided to remove hubs and check all wheel bearings and to no surprise, they are needed all the way around. Anybody got a good source for wheel bearings ...walt's tractors had best price of $31.03 for seals, bearings, races...but they can't get them at this time. Local NAPA wanted $28 for a seal and $17 for a bearing.</p></blockquote><p></p>
[QUOTE="bobtaildog, post: 77590, member: 11066"] So an update on this project, I did remove the hoses from the right side drive motor and capped it at the tandem pump......i can kill the motor with forward and reverse movement of the swash plate. So in the process of all this, I decided to remove hubs and check all wheel bearings and to no surprise, they are needed all the way around. Anybody got a good source for wheel bearings ...walt's tractors had best price of $31.03 for seals, bearings, races...but they can't get them at this time. Local NAPA wanted $28 for a seal and $17 for a bearing. [/QUOTE]
Verification
Post reply
