I am at the assy process after changing barrings and chains and seals and a couple hosed and those pesky orings. You had mentioned you got your brake working again..How did you do that?
Awesome! I was wondering how your repair was coming along. As to the brake, I just had to adjust it. The rod between the pedal and brake caliper is threaded. I had to snug the nut up a few turns. Now I have to remember to release the brake when I start moving. The Bobcat has enough power to overcome that brake, so it's easy to forget you have it engaged.
