So, I was using my 853 and all of a sudden it died. No slow death but an abrupt stop. Checked a couple things, and finally found the engine fuse had blown, grabbed the other and swapped it over. It ran for about 5 min then blew again. Did this a couple more times to get it in a good spot to work on it, each time it would blow faster, then it ended up blowing the moment the key was turned to run, not even start. So Having a need to spread 40 yds of loam that was delivered I did a semi quick diagnostic and bought a dozen more fuses and found there to be 2 orange wires and a blue wire on the run terminal of the ignition switch, the wires all seemed to relate to running the bobcat, so one at a time disconnect and reconnect to find the fault. Ended up being an org and a blue wire that were factory joined causing the issue, cut the org off and it runs and has gauges. Finished the job and brought it home. So this was about 2 weeks ago and haven't delved into the "short" yet, I had a suspicion that it may have to do with the aux hyd circuit, per the wiring diagram.....Now this machine hasn't been cut up that much that I could tell. After doing some more research and checking the parts manual, and the service manual, I have come to the conclusion that there are several types of aux. hyd. on these. A: built from factory with the aux in the hydraulic control valve, with the control module B: opt. "maybe dealer installed?" aux control valve under seat on left hand side C: JEM - select valve? D: Apitech valve I believe I have "A" because I have no separate aux valve as it shows in the parts or service manual. Now there is no way in hell that I'm even going to consider bending over for a control module from bobcat. So I would simple bypass the control module and rig up a switch and some relays to accommodate the aux valve electrics. So my ?....I know long winded.....would the solenoids be shorting out? I highly doubt it, the fact that the fuses had a incremental death march from 5 min to nothing would indicate in my mind that it may be the control module....ie: circuits frying inside. And yes I checked out all wiring for cuts and scrapes for shorts. Thoughts?
