Just a follow up on my progress. Just to be sure, I have switched the joysticks back and forth now a few times just to make sure about my conclusions. And the left joystick continues to control machine movement regardless of which side it is connected on. And the right joystick continues to control lifting regardless of which side it is connected it. So... clearly the joysticks aren't entirely dumb as they "know or remember" what they are supposed to control regardless of which sides connector, they are plugged into. So I can't fully isolate the Joystick as the problem. When turning right or left the system will click off with a couple of beeps. If I am very delicate and barely turn right or left, just nudging the turn, it will work, though very slowly, eventually clicking off. If I go for 50%+ or more flow in either direction it will 99% of the time it will click off immediately. On very, very rare occasions, it will work really good and turn with full normal flow. In fact, few times It has continued to turn rapidly and required some jiggling around of the joystick to get it to stop turning. One Joystick is about $1,100.00 and not in stock locally, so I guess I will have to buy a new one and just see if it resolves the problem. If something beyond the joystick is causing a problem with flow to the wheels for turning I guess I will have to tackle that next. Though it seems all the Error codes indicate a joystick problem. Current codes are 39-07 Y-Axis Not In Neutral, 75-01 CAN JoyStick Information Error. All of which pop up at various times when system goes off.
