My 05 t190 has a large hard line that comes from the main lift cylinders to the main control valve where it connects to a large "t". The t's tube is running horizontal and connects into the center of the main valve body. The male fitting that it connects to is vertical and the nut size is 1 inch. My problem is that the o ring that is mounted on the male end at that point keeps blowing out. I tried to get one from Bobcat, but the parts guy was unable to find it and when I told him to just give me several sizes and I'd figure it out, he said they were't normally stocked. So my best guess at what's going on is that I'm either using the wrong size or the wrong hardness or both. The best fit I've found using my kit is a 10 mm x 1.5mm N70. Should I be using an N90 instead? Is my size correct? Thanks in advance. Jim
