jplacz2000
- Dec 27, 2011
- 29
just got aa used machine john deere 5575 dash doesnt light up and have to run key on service position to load if switch back to normal have to hold key on to keep running
is hat under rear hood left side by some chance???fuses? Cheapest thing to replace first would be starter interlock relay. I think the display is a 5 amp fuse.
Yes , new Holland made the john deeres of that year so it should be in the engine room fuse box left side. There are two large relays on the bottom and the starter interlock is just above them on the left. You could post this in the new Holland forum and see if Mike10 has some insight too.is hat under rear hood left side by some chance???
