I have had a engine knock in an old 500 for a while . Today I thought I would find out where . It sounded like it was in the front cylinder . I pulled the belt and the knock went away . OK its in the jackshaft or front pully or the chain cases . Pulled the wheels and opened the cases and started the engine . The left jackshaft sproket had .030 run out . Now I know where the knock is and I think the PO dinged the shaft under the block where it slides to change belts . So I guess I will run it till I find time to pull the motor so I can get to the shaft to clean it up and fix the wobble . Hope this helps someone else solve there problems .Gearbox
