richardgreenfield
- Nov 14, 2014
- 10
Any tips on controlling bucket lowering speed with s510 with heavy bucket i.e some sort of flow valve or adjustment on valve block regards
Hi its foot control and yes you have some control but not any finesse hoped that fitting a flow re stricter in line will help regardsNeed a little more info. Hand or foot controls? Does the lift just fall or do you have some control?
Is this new or always been this way?......... might want to jiggle your right stick back and forth could be your aux hydro sticking a bitHi its foot control and yes you have some control but not any finesse hoped that fitting a flow re stricter in line will help regards
Hi always been like this I suspect problem to be extra large bucket that is fitted regardsIs this new or always been this way?......... might want to jiggle your right stick back and forth could be your aux hydro sticking a bit
Antfarmer most machines built in the last 15+ years have electric solenoid controlled auxiliaries.Hi always been like this I suspect problem to be extra large bucket that is fitted regards
Have you ajusted the linkage?.......Hi always been like this I suspect problem to be extra large bucket that is fitted regards
Thank you OM still learning only one I have is a 743Have you ajusted the linkage?.......
Possible it could be somthing with the vavle. Generally they are set up so the unit has to work to lower so you can control speeds. Or it is simply poor operating technique.Thank you OM still learning only one I have is a 743
