Try cleaning the gunk off your aux soliniodsDo you have another button to change the aux flow?
Yes I have high and low flow. doesn't work with that either. Stupid question where are aux solenoid switches ? ThanksDo you have another button to change the aux flow?
I think they call them stems should be right by the spools on the hydraulic block where a bunch of lines goYes I have high and low flow. doesn't work with that either. Stupid question where are aux solenoid switches ? Thanks
I have to tilt cab up its underneath right. I changed pickup tube in fuel tank last year now I'm wondering if I disturbed contacts. Pickup tube job was a nightmare hope this is easier. ThanksI think they call them stems should be right by the spools on the hydraulic block where a bunch of lines go
They can get alot of crap in there should not be to hardI have to tilt cab up its underneath right. I changed pickup tube in fuel tank last year now I'm wondering if I disturbed contacts. Pickup tube job was a nightmare hope this is easier. Thanks
And yes will have to pick the cab up best to tie it back for saftyThey can get alot of crap in there should not be to hard
