case 60xt hydraulic issue
blazerboy72
I'm looking at a 60xt that has some kind of hydraulic issue. The owner says it runs fine for 30 minutes to an hour and then the right side operates slowly. Does anyone have an idea what would cause this? I want to see what the repair cost would be and make sure the purchase price is reflective of such.
bobcatguy
I'm not sure he said the hydraulic filter was replaced but I don't know about a case drain filter.
I've never looked on a Case but Bobcat has case drain filters that are housed in small (about 2" round by about 4" long) aluminum round housing. It normally comes off a small line on the drive motor. If you can find the case drain filters you can open the side that is causing problems and look to see if there is metal in it.
