ls170 pouring fluid
rigderunner
I blew the hydraulic cooler line hose last week finally got it repaired now when i put hydro fluid in the resevoir and attempt to start it fills the left side of the belly pan full which eventually fills the whole pan and drains out of the drain hole Any ideas of what could be leaking any help would be greatly appreciated hadnt had this machine long And the hydraulic fluid leaking is getting very annoying
Just had this on my bobcat I pulled the drive motor and replaced the seal in the case I made a set tool out of pvc coulpler and a square threaded plug do both sides
clean it good with a pressure washer and then lift the seat and watch for leaks. Sounds like the tank either has a hole in it or the suction hose is leaking or loose. If you still cant see much drop the belly pan under the engine. May be something wore a hole in the bottom if the tank,
R
rigderunner
Thanks for the replies guys iam gonna try to take a look tomorow
