7LBSSMALLIE
- Feb 2, 2012
- 1,294
mustang 2054. not real fammilar with these quick look. brakes spring applied pressure released .in my case. started by verifing brake release coil would magnetize whenn 12 v applied. yes put it back on . applied twelve volts to coil yes brake release therby confirm elect not hyd. it being intermittent need to chase wires.(so if anbody can provide a schematic it would be most welcome.) i failed bad looking online to locate one. / MY THINKING AT THIS POINT . is A. the fact that is intermintent and sometimes they partialy release is that my supply wire is breaking down as in will carry volatge but not a load. B. got no idea how the little brain box works? C. my dillema being is chas wire outa brain box to coil: can do physaccilay but a pain. as well as do not know what demands need to be met to relese brakes as in will a low volt seat belt. effect the brain box..LET IT BE SAID THAT JUST BYPASS THE THE SAFTEY FEATURES IS NOT AN OPTION. NOT NOW NOT EVER NOT ANYONE,
