New holland L781 I was using the skid steerer and after awhile the left side got sluggish and finally would barely move so I checked all fluids and let sit over night the next day I get onit and crank it and the left side drive took off I couldn't stop it. Killed the motor and cranked back up the tires didn't move I thought I had it fixed but wich ever way I move the stick that's the way the wheels turn and there is no way to stop it unless you turn motor off. Crank it up again same thing if I push forward the tires stay forward if I cut motor off and crank it again and pull reverse the tires stay in reverse. Any suggestions?
